did I damaged my car or am I still safe 🤔😕
I have a 2003 mercedes e500 that I didn't drive for awhile today i took it for a test drive, While I was driving I noticed rubbing noise coming from the rear, so in order to determine what is the noise and where it's coming from I needed to be out of the vehicle watching and listening to the rear tires while they spinning, so I had lifted the rear end off the ground while the front end on ground, I had turned it on and put it in gears by the time I got out and reached the back of the car, I saw only the left side wheel turning constantly, While the right-hand wheel rotates slowly and intermittently, like a clockwise rotation, the question here is this normal or I just damaged my car? I usually don't do this unless I lift it from all sides, but this time I forgot, so now I'm obsessed that this might have caused damage to the differential or the axles. I would be grateful to anyone who has knowledge of this and has responded
oh yeah The nightmare is gone😀
thanks to you both, Heguli and Super Member, You guys have calmed my brain, I've never knew about open differential and locking differential before, I was just comparing it to my second vehicle which is toyota camry front wheel drive that when I lift the front, Both wheels rotate evenly
Rubbing noise could be from the brakes. They might be seized or stuck after a long period of not being used. A few firm brake presses while driving may help. But if the sound is very bad or you see smoke coming from the brakes, then I would recommend a brake job.
Hey if you read the manual braking section I think you'll have a couple options, I even read you can firmly push the brakes while at a higher speed(says make sure no car is behind you) to give your brakes a better grip, and even recommends pushing the brake firmly before parking to help the brakes, and also mentions the ((P)) is a parking brake and should be used when you PARK the car , so I gained a lot of insight, I found a manual online I have saved if you need the link, I'm in an 05 E500 but you can click the year and model to get a different manual https://www.carmanualsonline.info/me...r-s-manual/1#6
