E-Class (W211) 2003-2009
2006 E350 Base 7 Speed help request
Old Jul 28, 2022 | 10:18 AM
Brianstrange's Avatar
2006 E350
I have a 2006 W211 (4/2005) VIN: WDBUF56J76A796616 -It's a base model with a 7 speed auto
Last night after getting off the highway, the car would not shift. It was in Comfort mode, I assume stuck in 2nd gear. Cycled the ignition, problem remained.
I got the following 2 codes from my Foxwell Scanner:
2350 - received from the control module 'N93 (Central Gateway (CGW/ZGW) control module)'
2204 - Signal fromY3/8n1 (Turbine Speed Sensor) is unavailable
Can someone confirm that it's the conductor plate? Also, I'm having difficulty searching parts because I'm unaware of the transmission codes. I did a search and came up with the following: ( Trans: 427 (7 speed auto) G906 (trans code 06) and GA auto trans ), but they dont translate.
Thanks in advance
Old Jul 28, 2022 | 11:07 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I had the same car and same problem. It was the conductor plate for me. What I did at the time was service the trans, swap the conductor plate, and put it all back together. Mobile tech came to the house - plugged in the old - took the software off of it. Plugged in the connector to the trans to complete the work - tech programmed the new. Problem fixed and the trans was updated to VSG3.
Old Aug 12, 2022 | 10:49 PM
2006 E350
I’d like to re-light this post with some new info. I cleared the codes and the transmission is shifting, maybe a bit harsh on slow downshifts. I did notice of evidence of leaks where it was parked, and trans fluid pretty wet on the bottom of the transmission. Is it possible that my codes are from a low fluid level?
Old Aug 13, 2022 | 12:02 PM
kjb55's Avatar
Check where the leak is coming from and if the fluid leak is being wicked into the wiring harness. Not an uncommon problem that causes trans issues.
Old Aug 13, 2022 | 04:23 PM
2006 E350
Meaning leaking out of the bulkhead connector on the conductor plate (o Rings)
Old Aug 13, 2022 | 07:14 PM
kjb55's Avatar
The connector at the Passenger Side Front Corner of the trans.
