CDI Engine Oil Consumption?
Yeah it was, actually so level that the water will not even drain off the driveway after a rain. I checked it again a few mins ago and it was full. The first time must have been due to the oil not yet draining all down to the pan like you say.
ASSYST reads 4,200 miles to go before service B.
The car is driven 50% of the time in slow moving traffic and 50% freeway.
Leslie Rushforth
Chesterfield
England.
leslierushforth@aol.com
Leslie Rushforth
Chesterfield
England.
I put the diesel oil in.
Regards,
John
Now some people might call this a benefit but others who have so-called free maintenance would not. It only extends the time until they are allowed to bring their car in for that free service.
Changing the amount of oil doesn't effect the length of time to the next service, it's the quality of the oil and length of time since the last oil change that matters. The type of driving you do also is accounted for.
You should be very careful not to overfill the crankcase because with too much oil, the crankshaft will beat the oil into foam. In fact I think Mercedes have told their dealers to put only 8 quarts into engines that would normally hold 8.5 in order to avoid overfilling.
I know of one person that was told to add 1 litre, then he was told that it was over-filled???
Thanks again for the reply,
John
An overcast afternoon in Torquay
Not sure about the diesel, but the gasoline motors have a drain-down period that has to occur before the oil level can be checked. If you check it immediatley after turn the car off it would probably indicate a low reading...
Totally agree with your point, and coincidentally both engines (320CDI and 500 petrol) hold approximately the same ammount of oil. 7.5ltrs
Rgards,
John
Dusk at Torquay
