E-Class (W211) 2003-2009
Load/torque Limit? How to change?
Old Oct 22, 2022 | 07:23 AM
LoGoo's Avatar
W211
Unhappy Load/torque Limit? How to change?
Hello guys. Recently i bought E240 W211 2005y. Me and my friend decided ti change the engine from m112 e26 to m112 e37. Only the bottom of the engine and injectors were different so we did it. Car works like a charm but only when you delicate press the accelerator pedal.... If you try to make takeover or smash the gas the car stalls (closes the throttle instantly for a secound) and bring error P20D4 in ECU - Load limit exceeded. After reading almost whole night i see that there is some load/torque limits in EGS52 or/and in ECU. Do you know how can i get propperly change this in DAS without breaking the transmission? Help please.
Old Oct 22, 2022 | 11:12 AM
tjts1's Avatar
C320
You've maxed out your mass airflow sensor and injectors. You need the larger maf from the 3.7 and injectors.
Old Oct 22, 2022 | 02:04 PM
LoGoo's Avatar
W211
I'm using MAF and injectors from 3.7 motor right now.
Old Oct 23, 2022 | 02:13 AM
tjts1's Avatar
C320
Swap in the maf from a 3.2 or 2.6. there were some changes in the MAFs over the years. Not all model year MAFs mapped the same.
Old Oct 23, 2022 | 03:21 AM
LoGoo's Avatar
W211
I tired with MAF from E240 and E320 the result is same... Thats why im thinking of torque limits
