E-Class (W211) 2003-2009
iCarsoft scanner
Old Oct 23, 2022 | 02:38 AM
ot1's Avatar
ot1
2006 E320 CDI
Arrow iCarsoft scanner
Who is using an iCarsoft scanner and which model? I have some questions concerning features and usage.
thank you
Old Oct 23, 2022 | 03:09 AM
My W212's Avatar
2010 W212 E350
I am using MB v3.0. Manual attached.
File Type: pdf
Old Oct 24, 2022 | 07:53 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Maybe post the questions you have...
Old Oct 25, 2022 | 10:25 PM
ot1's Avatar
ot1
2006 E320 CDI
Arrow
I have the CR Max, vehicle 2006 E320CDI, I had a presale question and its capability compared to your model, they told me that it did. But there are issues with the CR max
1. I am unable to use ABS brake bleeding because it says the function is not available.
2. there doesn’t seem to be any way to look at the glow plugs or test the control module
3. The check smooth engine running function only shows four injectors, other tests also only show 4 as well.
4. Fan shows 90% when its not even spinning, I can’t find a way to just turn on the fan to test it.
I have more issues as well.
Old Oct 26, 2022 | 07:54 AM
tjts1's Avatar
C320
You have the wrong icarsoft.
Old Oct 26, 2022 | 11:24 AM
Heguli's Avatar
2006 E280
I have 2006 E280, and iCarsoft MB V2.0, also found those same issues. For the bleeding function, I figured it's only for the cars with SBC brakes, which I don't have.
Old Oct 29, 2022 | 04:40 AM
ot1's Avatar
ot1
2006 E320 CDI
i have SBC, it says bleeding is not available. POS.
you have a 6 cyl engine? How many injectors does it say you have?
Old Oct 29, 2022 | 04:45 AM
ot1's Avatar
ot1
2006 E320 CDI
what engine is in your 04 E320?
which iCarsoft do you have? You can test glow plugs? Access the engine fan? You can bleed brakes on your SBC?
Old Oct 30, 2022 | 04:30 AM
Heguli's Avatar
2006 E280
I can't remember right now. I did went through the functions some time ago, but injectors weren't the issue.
Old Nov 1, 2022 | 12:40 PM
Heguli's Avatar
2006 E280
Had some spare time today to fiddle with the scanner, and I have all six injectors.
Old Nov 3, 2022 | 03:21 AM
ot1's Avatar
ot1
2006 E320 CDI
thanks for checking, what engine do you have? OM648?
Old Nov 3, 2022 | 07:40 AM
Heguli's Avatar
2006 E280
I have OM642.
Old Nov 25, 2022 | 06:47 AM
benko286's Avatar
w210 290 TD; w639 - 111CDI;w212- 350 CDI;W205 - 220 d
Hi,
I am planning to buy iCarsoft scanner, I know that I cannot expect same functionality as on real WIS/EPC.
My question is more about should I buy iCarsoft MB V3.0 or iCarsoft CR MAX 2022.
My garage is only Mercedes, but my sister and her boyfriend do not have Mercedes (yes I need to persuade then on getting one of them.....) so diagnosing VW or Hyundai could be useful for me/them.
My question would be here, if anybody knows, can CR MAX 2022 do all which can MB V3.0 for Mercedes, since my only worry would be that the general one could lack some of the functions MB V3.0 has?
Old Nov 30, 2022 | 12:37 AM
ot1's Avatar
ot1
2006 E320 CDI
Originally Posted by benko286
Hi,
I wish there was a forum for scanners here because I am disappointed with my CR max, it can’t bleed the sbc, Shows not available. It shows only four injectors out of six, I have the OM648. Also I am unable to find out where I can look at the glow plugs, I don’t see the GP controller module. There are also other issues. I am composing a letter to iCarsoft tech services to see if they’re going to address these issues. Oh and my most recent software of any listed vehicle is 2019, I bought my CR Max last year 2021. The opening screen proudly displays “PROFESSIONAL”, there should be a Scanner forum, maybe with even sub forums to dissect features.
Old Dec 21, 2022 | 01:12 PM
benko286's Avatar
Thanks for the info.
If to somebody means something, I have found out that CR Max and MB v3.0 have same features for Mercedes, except CR max supports other vehicles as well.
Would you maybe recommend some other diagnostic tool for this(can be only Mercedes), Autel maybe?
Old Dec 21, 2022 | 04:04 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
I do have iCarsoft scanner (EU Pro multibrand version), and thought it works well until I took the jump into XEntry (MB tool).
For XEntry I cleaned up an older (i7 4th gen) laptop, upgraded to SSD, bought the Tactrix OpenPort J2534 close (AliExpress), and downloaded a XEntry package via YouTube (cheaper than iCarsoft since the laptop was a write-off by then). Though I cannot do coding, it is a ton better than iCarsoft. I cannot tell about the Autels..
Old May 21, 2023 | 04:11 PM
mkeller's Avatar
E320 CDI
Did you find a solution to injectors 5 and 6 not showing? I'm having the same problem.
Old Jul 17, 2023 | 03:30 AM
ot1's Avatar
ot1
2006 E320 CDI
hello, do you remember how much your paid for the Tactrix device and connecting cable? Software included?
