Stuck in park
I have a 2007 w211 facelift, and can’t get the shifter to release from park. I have a second car I use for work so i don’t often drive the w211 in the weekdays.
I drove the car home on last sunday and there was no problems. On Wednesday I was going to drive it after work, and I couldn’t get it out of park. I let it be and tried again today, but still no success.
No warning messages, and the brake lights are working. I’ve tried to push the brake a few times before trying to change gears, and I’ve tried to hold the brake pedal for a while.
I also tried pushing the manual release button under the center panel, but it didn’t work. It’s completely stuck.
Any suggestions? Thank you
Is the brake light switch the black little box you can access behind the cover under the steering wheel?
Even though the brake light switch is faulty, would this still mean I can’t release the gear stick with the manual release button inside the center console?
The other most common problem I have read about is spillage on top of the gear stick, but then the symptoms are that the gear indicator in the dashboard is gone. But it’s still there for me.
I can move the stick from the normal position to the right, but not downwords to change. It stops.
