E-Class (W211) 2003-2009
Brake caliper slide bolts
Old Jan 3, 2023 | 05:31 PM
jpiombo's Avatar
2004 e500 wagon 4matix
Hello Friends,
I am having the time of my life trying to replace the brake pads on my 2004 E500 wagon
My caliper bolts are stuck. PO has them fastened with Torx bolt T40?
They will not budge at all. I’ve sprayed it down with penetrating oil and nothing. Applied heat. Etc.
Any suggestions please…
Warmest Regards,
john
Old Jan 3, 2023 | 07:31 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Not sure if it help, but try a couple of vide that pertain to your issue on YouTube....GL
R,
2Merks
Old Jan 3, 2023 | 09:53 PM
Sandygear's Avatar
2004 e500
Now hear me out on this...... Are you turning it the correct way?
I'd recommend you use a impact driver, a real one.
https://www.harborfreight.com/6-bit-...RoCkyEQAvD_BwE
Old Jan 4, 2023 | 04:30 PM
pinebaron's Avatar
07 E320 Bluetec
1. Use a high heat heat gun
2. Use a long breaker bar (like 18" or longer)
3. Use a jack stand to push the breaker bar up (last resort)
