E-Class (W211) 2003-2009
Cap for temporarily sealing ends of hard brake lines?
Old 01-09-2023, 06:35 AM
RA030523's Avatar
E320 CDI
I'll be pulling and transferring hard lines from one chassis to another and need to keep debris out.
Looking for recommendations on what I can use to temporarily seal off the ends of the lines.
I note that there are six lines coming in/out of the SBC, so I figure I'll need a total of twelve caps?
Old 01-09-2023, 10:10 AM
juanmor40's Avatar
Received 1,712 Likes on 1,063 Posts
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 (W212 @100K), 2015 ML350 (W166 @96K)
Here is an idea (never used them myself)
https://www.amazon.com/smseace-Silicone-Reusable-plugging-Transmission/dp/B09YY2TPFR/ref=sr_1_2_sspa?keywords=brake%2Bline%2Bplug&qid=1673276969&sr=8-2-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzRzE5N001Vks0SUNYJmVuY3J5cHRlZElkPUEwOTgwMTgxMUZRWVNENlhaSjFGRSZlbmNyeXB0ZWRBZElkPUEwMjc0NTc4MjMyWENZVjlOQlAyTiZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1 https://www.amazon.com/smseace-Silicone-Reusable-plugging-Transmission/dp/B09YY2TPFR/ref=sr_1_2_sspa?keywords=brake%2Bline%2Bplug&qid=1673276969&sr=8-2-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzRzE5N001Vks0SUNYJmVuY3J5cHRlZElkPUEwOTgwMTgxMUZRWVNENlhaSjFGRSZlbmNyeXB0ZWRBZElkPUEwMjc0NTc4MjMyWENZVjlOQlAyTiZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
Old 01-09-2023, 11:27 AM
Heguli's Avatar
2006 E280
I've used electrical tape or duct tape if I don't have the correct plugs available. Works just fine if only purpose is to keep debris out.
Old 01-09-2023, 07:20 PM
ot1
ot1's Avatar
2006 E320 CDI
I also used electrical tape but with a piece of blue scott towel wrapped first to keep the tape from falling off once brake fluid gets to it.
Old 01-10-2023, 03:22 AM
RA030523's Avatar
E320 CDI
OK, yeah, tape (and or/with paper towel) is likely the best. Don't want to add bulk (unless it gets threaded onto a fitting it's going to be prone to being bumped off when routing on/off).
Thanks!
Old 01-18-2023, 12:32 PM
RA030523's Avatar
E320 CDI
I found that I could use some silicone stopper plugs (for short-term use they seem like they'll work). Bought a pack of assorted sizes off of Amazon: have also come in handy for sealing up the line holes in the SBC. The smallest ones are tiny and a bit fiddly to install/push into the small dia brake line hole but heavily twisting while gently pushing seems to "screw" them in enough to hold (but probably won't take much of a bump to pop out).
Quick Reply: Cap for temporarily sealing ends of hard brake lines?
