w211 Windsheld wipers start before washer pump
Some sort of delay circuit would be needed to operate the washer before the wipers.
Though knowing how Mercedes is built, it would be rather difficult, or even impossible to build such a circuit, for a rather little use.
Override button for the washer pump, and when the rain sensor detects water it automatically wipes the glass.
https://mbworld.org/forums/e-class-w...ml#post8419721
His solution not only works, but it is elegant. You can remove it, and return it to the stock installation. Recall that for the W211, you need to take out the right fender and be careful not to break crusty plastic; otherwise, may need a new pump/hose/reservoir.
Parts (sample for visuals), sure you can get them anywhere and you only need a few inches of tubing.
Valve: Tubing:
