E-Class (W211) 2003-2009
Battery in the back kind of wet, car tries to start and dies
Old Feb 4, 2023 | 02:03 PM
Mercedese200200's Avatar
2006 E200
Hi guys, my cars HOLD function stopped working and the seat heater in the drivers position stops working, that was cause I forgot my window open during rain, now during the winter the back gets wet around the battery area, earlier I had the same issur but after connecting with cables to another car mine started right away, now I charged it for 20 mins and it doesnt start, any ideas?
Old Feb 4, 2023 | 02:24 PM
Heguli's Avatar
2006 E280
Get the battery load tested. Might be on its last leg.
Old Feb 4, 2023 | 02:32 PM
2006 E200
Appreciate your reply, but I only have issues like every 5,6 months, and as I stated I'm aware there re some electrical issues, do you think if the battery is in last leg can work properly for several months and only fail often?
Old Feb 4, 2023 | 03:17 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Purchase a BA-5 battery tester and place it on you battery every oil change. You can track the battery degradation over time. New, the battery in my w211 is rated at 900 CCA and new batteries will always test over 1,000 cca. When the tester shows my battery at 700 CCA I replace. It is not as quite as accurate as load testing but it gives you a very good idea when your battery is about to fail to start your car. I would rather replace a battery then be stuck on the side of the road at a truck stop in the middle of a 500-mile journey. FWIW YMMV.
Old Feb 4, 2023 | 07:16 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
What is your goal? to start the car, or to fix the car?
If it were my car, I would start by scanning the car for error code, and know them ahead of time. Then, start emptying the trunk and carefully check if there is any water around, find the entry point and fix it.
Check there is no moisture on either of the fuse areas. There is one in the left area of the trunk, and in some models one near the battery (pre-fuse box).
Also, if you car got water through the windows on either of the driver or passenger side, be certain there is no water below the carpets and ALL the modules under the carpet are DRY. Any moisture in them will certainly give all kind of surprises--> MB water gremlins. MB do not like water inside ANYWHERE. You may have a damaged module already
Once all the above is done, be certain your battery is up to the task as it has strongly been stated above, either a new one or yours verified is properly charged. Then, approach the error codes you got.
Anything else, and you will be on the road again for a short lived moment.
Old Feb 5, 2023 | 05:02 AM
Heguli's Avatar
2006 E280
Like I said, might be. That's basic procedure in our shop to start from the battery if there is any problems of starting the engine. You might have just a corroded battery post, as you said it started just fine when jumped from another vehicle.
