2009 e550 4matic P0730 code
I have replaced my car conductor plate along with the gasket and connector pin with new fluid car drives very good now but check engine light stills shows the code stored did he forget to clear it with his Star tool car drives normal
Ok
ask him
if you had a transmission fault that fault is stored in the TCM and also sent to the ECM where it is read via the OBD to learn the transmission fault you have to read the TCM------- fix the problem and clear the fault in both places
ask him what he did to your car
ok so he reset the code but it still showing up in my check engine light but he fixed the problem does that mean it’s still a problem With the transmission but the car drives fine
