E-Class (W211) 2003-2009
K & N Air Filter.
Old Oct 22, 2004 | 08:49 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
K & N Air Filter.
I asked this in the E55 forum and didn't get a response..
I noticed in another thread that someone said you get about 30HP increase using one of these in an E55.
Does using an air filter "really" give you more power.. I am sure someone in this forum has tested this.
Has anyone here added one, did they notice any improvement?
Thanks.
Old Oct 22, 2004 | 09:23 AM
ZEEOHHSIX01's Avatar
01zo6 03 lightning 05 e500
the e55 is supercharged so if there is a restriction in there stock air box they will gain lots more power than our n/a cars. from previoud dynos my dakota rt 00 made and xtra 5rwhp& 2rwtq across the entire board with a k&n fipk cold air kit. i think max power was up 6rwhp some where but max is not what your looking for u want power across the whole rpm range. my 01 zo6 with a varam did not show any improvment on a dyno but went .2 faster in the 1/4 and picked up 3mph trap with close to same conditions at the track. i think the filters are worth it becuase u can clean them and reuse ends up saying $$$$ in the long run just dont expect to notice a huge gain hope this helps
Old Oct 22, 2004 | 09:51 AM
miamigrrl's Avatar
2008 ML350 4matic
Thanks.
A 30hp increase from just changing the filter sounds like way too much. I've always understood that gains from changing a filter, even on a supercharged car, are negligible.
I stayed away from the K&Ns when I had my 2.7T because of various reports that the oils in the filter tended to foul the MAF.
btw, ZEEOHHSIX01, reading your post made me dizzy.
