Manual Sunroof Crank Tool
2015 ML 350
Sunroof's Manual Crank Tool
How does one use the emergency sunroof crank tool? In the manual it says it is inserted in the forward roof console. Where is the little hole? Is it behind one of the light lenses? How do you remove the lens without breaking it?
I'd hate to be in a rush in a rainstorm & break the whole danm thing apart!
if you look above there is a square plasic piece by the light where you can push. Just push on it and it should pop out and thats where you put the crank tool to manually close the sunroof.
