E-Class (W211) 2003-2009
Odd codes and behavior
Old Mar 19, 2023 | 05:43 PM
Faszerf's Avatar
e250 bluetec
Hi guys, I recently purchased an e55 amg with 62k miles.
Theres a couple things I'd like to address, hoping you guys can help. I'm wondering if I'm having an issue with my rear SAM module.
The rear shade is stuck in the open position, I can hear a slight VERY faint click when I press the button. Ive tried wiggling it to go down, no luck.
The previous owner spent 1800 bucks fixing the pano roof so that works. However the mood ambient lighting in between the two glass sunroofs does not work whatsoever, even when pressing the brighten button.
When I bought it the trunk close button on the trunk did not work. I took a close look at the wiring hareness on the left side of the trunk arm and noticed there were 2 broken wires and 3 that were about to break. I soldered all these wires back together and the trunk now closes with the button. I think I've addressed this issue fully.
I read that broken/shorted wires can fry the rear sam module and I'm wondering if thats why the roof lighting is not working. There also a code for a short in the right driver side mirror heater.
I've gone ahead and attached the printout for all codes.
Thanks!
File Type: pdf
Old Mar 20, 2023 | 11:53 AM
e350forme's Avatar
fleet
did you try the rear shade trick with 2 people? one pressing button and one pressing wiggling the shade?
dont know anything about the rest sorry
looks like a standard MB printout with all the dif errors.
