E-Class (W211) 2003-2009
Skipping 2nd
Old Oct 23, 2004 | 09:23 PM
ems211's Avatar
Skipping 2nd
I was wondering if anybody had this problem... I own a 04 e320... and when I use the manual shifting... It goes from 1st to 3rd at high rpms and skips 2nd but it doesnt skip any other gears at high rpms... for ex. 2nd to 4th skipping 3rd... only 2nd... I showed this to the dealer and drove with the tech. to demonstrate this problem and he did not know anything about it... It was more like well if it works than there is nothing wrong with it... does anybody else have the same problem...
Old Oct 24, 2004 | 01:58 AM
Hussain's Avatar
too many to list
I know with my 55 when you set it to "C" it starts off in second gear. I know your situation is different, however, try setting it to "S" and see if it changes anything.
Old Oct 24, 2004 | 06:53 AM
ems211's Avatar
re: skipping 2nd
I do have it in s mode and still skips 2nd... I don't know what to make of it... thanks for your help...
Old Oct 24, 2004 | 07:46 AM
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
These are supposed to be intelligent gearboxes and if you are 'flooring' it or accelerating hard in first, then it might decide that 3rd gear would be the next most appropriate gear?
Just a suggestion.
Regards,
John
Old Oct 24, 2004 | 12:31 PM
koko381's Avatar
2004 E500
I thought the same situation too when I would race some people off the line. But it is not skipping second on its own. Manual mode will still shift gears by itself. So you are changing gears the same time that it is changing gears and it seems to skip second. But in reality you are skipping second. Try it out again and dont shift, it will shift for you. I am not a big fan of that cause basically we dont have a manual mode. Guess its a safety function.
