E320 CDI motor mounts unbolted, but engine won't lift
Subscribe
May 13, 2023 | 06:49 PM
2005 E320 CDI with OM648 engine
I'm replacing motor mounts and jacking the engine at oil pan is
lifting the whole car.
All 4 bolts on the mounts are removed. What the heck is going on? Is the engine attached to the frame somewhere else? How can I lift the engine to pull mounts out?
Reply 0
May 14, 2023 | 02:16 AM
How much did you lift the engine? Suspension will lift the front end up when you unload the engine weight from the subframe.
Reply 0
May 14, 2023 | 01:04 PM
The transmission mount bolts need to be removed...
Reply 0
Subscribe
Currently Active Users (1)
