E-Class (W211) 2003-2009
Cracked rubber
Old May 27, 2023 | 02:34 AM
Tom pepicelli's Avatar
R320, S211 wagon
Cracked rubber
Hey guys,
Got an S211 with a crack on the window rubber seal.
Does anyone know of a product that can glue rubber?
I want to try fix it before the rubber completely separates.
Old May 27, 2023 | 08:27 AM
chassis's Avatar
2017 GLE350 4MATIC
Is replacing the seal an option? If it was my car that's what I would do.
Old May 27, 2023 | 07:15 PM
jpeter6981's Avatar
2014 SL550, 2014 GL350, 2002 CLK430 Cabriolet
Tom. I will tell you from experience, that rubber is in much poorer condition than it appears. If you remove the window, it will be crumbly and "gooey." I could not find just the rubber and had to replace the entire window/rubber on each side to repair.
Old May 27, 2023 | 07:21 PM
tjts1's Avatar
C320
Yup got the same problem around the rear door quarter windows on my wagon.
I might cut what's left of it and run a bead of RTV.
Old May 27, 2023 | 07:25 PM
E55Greasemonkey's Avatar
This place is a joke.
This is normal wear and tear for the 211, you'll need to replace the entire glass as the seal is permanently bonded to it. Better hurry before they stop making them.
Old May 27, 2023 | 07:41 PM
jpeter6981's Avatar
I did both of mine as well as the rearview mirror surrounds and the windshield scuttle rubber. These are absolutely common wear items.
Old May 29, 2023 | 06:17 AM
R320, S211 wagon
Thanks guys for the suggestions, appreciate it.
Seems to be a common issue, my roof rail seals are also cracked up.
Do any of you have a part number for the entire window/seal on both sides?
Would like to get this problem fixed, especially before they discontinue them.
Thanks.
Old May 29, 2023 | 02:04 PM
Thanks.
You'll have to look it up by your VIN number. Be aware there are at least 2 colors of glass here in the U.S....blue and green. There may be other variations outside the U.S.
Old May 30, 2023 | 07:07 AM
R320, S211 wagon
Ok, thanks
Old Jun 1, 2023 | 01:20 PM
tyabnet's Avatar
2000 C230 - 2001 E430 - 2003 E320 -
It would help if you pick up your own EPC/WIS software - then you can find all the part numbers and factory workshop repair instructions. Look on ebay for it. They run in a VM and don't cost much. Would also suggest you practice safe computing and don't let that VM access the host internet...
