E-Class (W211) 2003-2009
Auxiliary battery location
Old Jun 14, 2023 | 01:19 PM
rocke320wag's Avatar
2002 Mercedes wagon
My battery in my 2006 E-350 Wagon just died. It's been in the car for over 5 years so it' was time. I want to change the aux battery also. Where is it located? Is there any special procedures I need to be aware of after changing? Thanks. All responses appreciated.
Old Jun 14, 2023 | 01:34 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Raise the hood. Standing in front of the car look to the back left of the engine compartment. There is a plastic cover containing the air filter for the passenger compartment. Remove that plastic cover and the auxiliary battery is located underneath.
Edit: after removing power from the car, you will most likely get an ESP failure notification on the instrument cluster when you first start the car. Turn the steering wheel lock to lock a couple of times to reset the parameters of the steering angle sensor. That will remove the warning on the instrument cluster. That should be all that you have to do other than resetting Auto up and down on the windows and possibly resetting the radio stations on the entertainment unit.
Also, do not have the key fob in the ignition switch when you connect the new battery. The arcs as you attach the battery clamps can cause blown fuses or damaged electronic modules in the car. If you have keyless go, keep the key fob at least 6 ft away from the car so no modules are active when the new battery is connected.
Old Jun 14, 2023 | 01:55 PM
2002 Mercedes wagon
bbirdwell Thanks for the information. Very useful. And thank you for your service to our country also. Hooah!
Old Jun 14, 2023 | 04:14 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
To the OP, do NOT take this advice lightly, it is worth a ton of money, $$$. An arc, and you can be paying top $$$ to replace the ESL, EIS, or some other expensive module. With the KEY in the ON position, you can take the ECU as well.
Old Jun 14, 2023 | 06:28 PM
2002 Mercedes wagon
juanmor40 Thank you for the follow up. I will make sure not to have the key in.
