E-Class (W211) 2003-2009
GPS Antenna and headliner
Old Jun 26, 2023 | 11:38 PM
nm4's Avatar
nm4
911,350Z,E63
Hi folks,
Bad luck w a parking gate which decapitated my GPS antenna. Has anyone else replaced it or found a suitable cover? The antenna works well but I am worried water will get inside and short the electronics.
Second question: is there a way to get access to the antenna without removing the entire headliner (ie just removing the back part of it).
Thanks in advance,
N
Old Aug 21, 2023 | 06:07 PM
IIGW's Avatar
2006 E500
Old Sep 11, 2023 | 08:56 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
Originally Posted by nm4
Hi folks,
Thanks in advance,
N
I replaced mine with an aftermarket GPS antenna when the original one failed. I found the GPS electronic module in the back left side of the W211 wagon. Sedan; it will be in the trunk left side I believe. I just installed the new 2" x 2" little square GPS antenna on the interior near a window facing up. Works great.
Not sure of the brand or part number but it was listed on these forums. Got it from eBays for under $20 but I had to make sure the new GPS antenna cable end connector was the right type to screw into the MB GPS module. There is another antenna for the MB S.O.S. System (similar to GM On-Star driver assistance) but I did not need that one other than to satisfy the MB S.O.S. system until I could get the obsolete MB S.O.S. system disabled with STAR de-programming. What a relief that was as that freaking outmoded S.O.S. warning was always coming up on the dash
