W211 Beam pattern - Both Halogen and LED
I didn't do this without prior research - Retrofitting HID would cost upwards of $700 in my country (incl. housing, ballast and bulb), and the H7 connectors on my car melted, presumably after the previous owner used an H7 bulb which had a power rating too high. The cables for the headlight adjustment motor is also cut off, which I'm not sure why.
After installing the LED lights, I noticed a couple of issues:
1. There's a cut(?) on the beam pattern which I didn't notice before (when it was using halogen bulbs). I understand the cut on the right beam is to avoid blinding incoming drivers, but the left one seems too big that it would only cause a part of the road to be properly lit.
2. Assuming this is the correct beam pattern, how should I adjust each beam to light the road uniformly?
The beam pattern looked like this (drawn out):
And in real life:
Front of the car
Inside
I hope I explained the problem well enough, since I never had this problem with my other cars (which didn't have any projector system whatsoever).
Thanks!
If there was a motor to move the lights, and wire is cut off, what position is the motor in? it seems it is turning left, and the headlights pointing that way.
Also forgot to mention, I manually adjusted the beam in the picture through the two adjustment screws on the housing.
If not done against a fixed mark, it is very subjective because it diffuses too much and with lights, there is always the chance the light may be getting into someone's eyes of the incoming traffic.
Update
I did not have YouTube back then, but here is the idea
Also: I dont know if you have projectors? But if you have reflector lights, then please dont use LED as this will blind other drivers.
