E-Class (W211) 2003-2009
NTG1 cannot set correct date
Old Aug 25, 2023 | 12:57 PM
gogydm's Avatar
08 E350
Everything was working as intended but I had to replace the battery on my car. After I reconnected the battery the date on the navigation and cluster became end of 2003, now it's early January of 2004. If I disable the sync between cluster and navigation unit I can set the cluster, but the nav unit again only allows me to change the time in 30 minute intervals. In the morning, after not driving the car overnight, the nav unit accepted the date I had set in the cluster, but when it regained GPS coverage it went to the wrong one again. Covered parking lot and removing the nav disk has not allowed me to change it manually. Is there anything I can try to get it to reset so I can adjust it manually and hope that with next GPS coverage it will stay that way? Xentry wasn't much help either.
