E-Class (W211) 2003-2009
2009 Bluetec with 2267-000, 2263-000 and 3066-000 Codes.
Old Sep 4, 2023 | 10:24 AM
rosenhauer's Avatar
2009 E320 Bluetec, 2006 E320 CDI (RIP), 2012 GL350 Bluetec (Sold), 2015 VW Touareg TDI
Like the title says I have a 2009 Bluetec with 2267-000, 2263-000 and 3066-000 Codes. The scan tool iCarsoft MBII just shows "The fault code is not found in the database" for all three of them.
We got the car as an insurance replacement just over a year ago and haven't put many miles on it. When we got it I had to replace the starter But no other codes at that time. Out granddaughter has been borrowing it and had it go into limp mode last week.
CEL has been on and the Glowplug light comes on from time to time with a failed to communicate with the GP controller. I pulled and cleaned the connectors at the controller and that seems to have taken care of that issue. Not sure if the other codes are related.
Also I did notice that the hose clamp at the intake to turbo was loose (guess it was missed when I did the air filters a year ago). It wasn't dislodged but loose.
Any help on identifying the issues would be greatly appreciated.
Old Sep 14, 2023 | 09:24 AM
rosenhauer's Avatar
As a quick follow up: I rescanned the car using the same scanner but in ODB2 mode not the Benz mode and it only shows 1 code a P3066 EGT Bank 1 Sensor 1. That's the one pre turbo. I've pulled it and have a replacement on the way. Hopefully the right one this time, the first one sent was a completely different sensor - wrong connector and had an "nut" threaded fitting instead of "bolt". I was however able to read the OEM part number from the dead one and got what MB says is the updated version coming. Fingers crossed!
I did test it by connecting it to my K-type thermometer the temp never changes when hitting it with a heat gun.
