E-Class (W211) 2003-2009
722.9 transmission valve body removal problem
Old Sep 17, 2023 | 11:26 AM
atikovi's Avatar
1995 S280 5-speed
The conductor plate connector is stuck in the transmission case when I try to drop the valve body. I'm trying to press it down from above with my fingers but it won't budge. There isn't much room for a pry bar either. Any other suggestions so I don't break it off?
Old Sep 25, 2023 | 01:13 PM
dacav's Avatar
2007 e350
I just removed the valve body out of my w211 this past weekend. I assume you were able to remove the wire connector that attaches to the conductor plate on the outside of the transmission. Once that is undone and the valve body was unscrewed, I was able to rotate the whole valve body from side to side while pulling down on it. Eventually it loosened and let go.
Hope that helps!
Old Sep 25, 2023 | 03:32 PM
atikovi's Avatar
1995 S280 5-speed
Piece broke off in the transmission but have to replace anyway.
