Braking Issue
Braking Issue
Hi guys, I don't think the brake pads are fully making contact with the rotors because the outer part still looks rusted and unclean. My brakes are relatively new, it's been about 8-9K miles since they were changed. I checked for any leaks, but didn't find any. Can you help me with this? Thanks.
2005 CLS55 AMG W219 C219
That looks like they need to bed in further, which is normal. But if you drove 8-9k miles, then it's something else. I suspect that the brake caliper doesnt work as it needs to. If it has sliding pins (floating caliper), then it needs to be able to move freely.
doxland (10-20-2023)
The brakes were working fine, and the car sat for a couple of months, and I had this issue. I was also thinking cleaning sliding pins, caliper, and bleeding the brake might work.
sal340 (10-19-2023)
And when installing new pads, clean the stainless rails, and make sure the pads move freely on those rails, if not file off any binding spots on the pads.
nd-photo.nl (10-20-2023)
