E-Class (W211) 2003-2009
E350 2008 Error Code P0072 & P2004
Old Dec 13, 2023 | 05:00 AM
sfsf7ob's Avatar
e350 2008
Component B14 ( Ambient temperature display temperature sensor) has short to circuit to the ground (P0072).
Diagnosis of tumble flab 'intake mainfold:short circuit to ground of sensor lines/Tumble flab shafts stick in the actuated position '(P2004)
Old Dec 13, 2023 | 08:31 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
P0072: Check the wiring to the outside ambient temperature sensor on the front bumper's lower part. Either the wiring is shorted, or the sensor is damaged already
P2004: Take a flashlight, and check the manifold flaps actuator at the front of the intake manifold. Likely broken --> New manifold
Old Dec 13, 2023 | 10:16 AM
sfsf7ob's Avatar
e350 2008
Thanks for your Reply.
