E-Class (W211) 2003-2009
Rear windshield squeak
Old Nov 15, 2004 | 10:01 AM
i8hotdogs's Avatar
Has anyone experienced the passenger side rear windshield squeak when driving? This only occurs in dry cold temperatures (40 degrees and below). It is completely gone in the summer time and when it rains. I tried to duplicate the noise from the door and rear dash with no luck. It has to be coming from the rear glass. Any input would be greatly appreciated. It's on a 03 E500 built in October 02.
Last edited by i8hotdogs; Nov 15, 2004 at 10:02 AM. Reason: Forgot some information
Old Nov 15, 2004 | 12:31 PM
konigstiger's Avatar
'71 Pinto
TSB P-B-67.00/09 MAR03 addresses corrosion of the MIG weld at the sealing flange under the polyurethane sealant for the rear window. This seems to coincide with your occurrences (only cold temperatures). Depending on how annoying the squeak is and how important it is for you to get rid of it; they will need to remove the window to clean the corrosion and paint the area. If you want a copy, pm your email address.
Old Nov 15, 2004 | 01:00 PM
i8hotdogs's Avatar
konigstiger - Thanks for the information, I sent you PM.
Old Nov 15, 2004 | 01:01 PM
i8hotdogs's Avatar
Anyone actually got this work completed? If so, how long did this take?
