E-Class (W211) 2003-2009
Xentry scanner help
Old Mar 15, 2024 | 08:57 AM
Jones1104's Avatar
2006 E350 base
Xentry scanner help
I bought a xentry scanner and have no idea how to use it to its full potential. It’s easy enough to use, but to do what I want and currently need it to do is what I’m after I’ve looked online for videos but the ones that are in English are only telling me how to do the basics. The ones that show you how to do in depth scanning and testing are in broken English or subtitled.
Does someone have access to or know of a comprehensive guide to using the system? As far as I can see I’ve bought an expensive scanner that can roll down the windows and pop the trunk. I’m not an advanced mechanic but I can figure most things out, but this is getting frustrating.
I currently need to diagnose the TCU on my 06 w211. It won’t move, but it’s doesn’t have any transmission codes showing.
Old Mar 15, 2024 | 03:39 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Try this forum...Hope it helps
R,
2Merks
https://mbworld.org/forums/mercedes-...mechanics.html
Old Mar 16, 2024 | 05:18 PM
Jones1104's Avatar
2006 E350 base
Result
It almost seems as though this is a CAN bus problem, as there aren’t any codes that correlate to the vehicle not moving
Old Mar 16, 2024 | 06:14 PM
Jones1104's Avatar
2006 E350 base
Those are the faults that came up in each category and are relevant to the situation at hand. Would you like to see the entire screen, would that make help you in same way/shape/form?
Old Mar 19, 2024 | 08:15 PM
Jones1104's Avatar
2006 E350 base
Quick results and CAN test results
Ran a quick test and a CAN bus test, results are posted
File Type: pdf
File Type: pdf
Old Mar 20, 2024 | 10:41 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Did you also see this thread in the W211 AMG section > https://mbworld.org/forums/w211-amg/...ts-o-pics.html
