Can Bulb Monitor Check be turned off to overcome LED flicker?
Doing so prevents the LED lights from flickering.
This was done on a BMW.
I'm wondering if we can do the same with our Benz.
Here's the article: https://www.car-auto-repair.com/bmw-carly-disable-headlight-bulbs-flickering/
Here's the video: https://youtu.be/4E80Q-8kbqg?si=YS5-VLkFN-qfmJFh
Thoughts?
I came across the article and video above and thought I'd post it to see if any of our experts here know if such a feature exists with our brand.
Getting the GLE stock lights converted to LEDs was very easy. The E350 is a very different story. I've tried different brand H7s and H11s coupled with different decoders with no luck.
While continuing to find a combo that works, I was hoping above could be used as a temporary workaround.
In theory if the bulb check is disabled, the LEDs should work without the flashing or flicker issue although the dash errors will likely remain.
Thanks.
