E-Class (W211) 2003-2009
Keyless go help
Old Apr 5, 2024 | 06:42 PM
bobby1153's Avatar
2009 mercedes e550
Keyless go help
2009 Mercedes e550 the keyless go feature on the driver's side door handle stopped working. All the other door handles are still working fine. I keep getting code 9024.
Keyless Go (KG) fault: Rear module; The antenna voltage is above the permissible range.
What could be the problem?
Old Apr 6, 2024 | 08:16 AM
Sandygear's Avatar
2004 e500
Remove door handle. Place test leads into connector. Measure resistance when inside button pressed, measure resistance when outside square button is pressed. Maybe door handle itself is no good.
Old Apr 6, 2024 | 08:19 AM
bobby1153's Avatar
2009 mercedes e550
I have tested it with my autel machine and the door handle responds when the buttons are clicked I don’t know why the keyless go function is not working
Old Apr 6, 2024 | 08:55 AM
Sandygear's Avatar
2004 e500
Originally Posted by bobby1153
I have tested it with my aureo machine and the door handle responds when the buttons are clicked I don’t know why the keyless go function is not working
Damn thats crazy. Guess it's time to replace the rear module.
Old Apr 6, 2024 | 08:57 AM
bobby1153's Avatar
2009 mercedes e550
I guess so
