E-Class (W211) 2003-2009
Rear ride height issue on standard E320? Photo attached.
Old Apr 22, 2024 | 04:15 AM
RxMB's Avatar
2005 E320 4MATIC
Question Rear ride height issue on standard E320? Photo attached.
Standard E320 4matic. High miles, all standard suspension.
To me, this stance looks odd. It looks too low in the rear like I always have a couple of body's in the trunk. Are the springs sacked out? What say you?
Old Apr 22, 2024 | 08:46 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
If I remember correctly, an E320 would not be air-matic. Ulrike went to the great junkyard in the sky a number of years ago, but as I remember, she had a distinct forward slope stance. Have the front springs or struts been replaced? If not, I would suspect the rears are sagging assuming the trunk is empty. There should be some ride height specs available to verify.
Old Apr 23, 2024 | 05:39 AM
RxMB's Avatar
2005 E320 4MATIC
Here is a pic I found of a 2005 with 31,000 miles. Looks a little different.
Old Apr 23, 2024 | 09:32 AM
robbieas's Avatar
'07 E350 (W211)
It seems like I've read a ton of people who went to do some suspension work and noticed a broken spring. I'd at least check that and make sure it's not that.
Old Apr 24, 2024 | 02:33 AM
Odd Piggy's Avatar
Yes. That’s what I remember. The tires to wheel arch spacing should be the same on both front and rear.
Old Apr 24, 2024 | 03:49 AM
RxMB's Avatar
2005 E320 4MATIC
Thanks. I thought so and will add it to the list! So either something is broken or wore out.
