E-Class (W211) 2003-2009
Grinding noise coming from engine
Old May 20, 2024 | 08:14 PM
liljojogotit's Avatar
E350
08 E350 70k miles making horrible grinding noise in the engine Bay Area. It sounds like it was coming from the front so I thought it would be the idle pulleys. I replaced both and the belt and still have this noise.
it happens both at idle and when driving. What should my next move be? Could it be a rod?
see video below:
Old May 21, 2024 | 04:42 AM
VivaJ73's Avatar
S211 E320 4-matic
Water pump?
Perhaps use a stethoscope to check the source?
Old May 21, 2024 | 09:07 AM
E500 AMG Sport's Avatar
Take the belt off and start it to determine if it is indeed pulley driven noise (water pump, a/c compressor, alternator).
Old May 21, 2024 | 10:34 AM
E350
thank you. I took it off and the noise was gone. I left the belt off and used a sethoscope to pinpoint the noise. Seems like it’s coming from the alternator and the power steering pump.
For the power steering pump do I just change the pulley or the entire pump?
Old May 21, 2024 | 01:09 PM
You stated you changed the 2 idler pulleys, what about the tensioner pulley?
https://www.fcpeuro.com/products/mer...ner-2722000270
Old May 21, 2024 | 09:22 PM
marcd7tx's Avatar
E500 Wagon, SL63 IWC, E450 Wagon
With a vehicle that age, i would change the ps reservoir for sure. It has a filter built inside of the housing that will most likely be clogged up at this point. at least that is the case with the M113/W211 Es. Not sure if it pertains to the W212. If your PS fluid is still a nice green color, then you may be ok.
