E-Class (W211) 2003-2009
Sway bar differences?
Old May 22, 2024 | 12:55 AM
MikeDanger's Avatar
bmw E39 540i
Hi all, I have a e500 wagon (4matic) however for some reason it did not come with a front sway bar (there USED to be one im sure)
So I have figured out the RWD and AWD are different. But what im not sure of is, are all the e350/350/500 AWD front sway bars the same? trying to find one at the local salvage yard but they only have e350 4matics
and is there a Sport version? right now this thing rolls like waterbed
Old May 22, 2024 | 05:07 PM
MikeDanger's Avatar
bmw E39 540i
could you just be kind enough to tell me?
I never go to any dealer EVER.
Old May 24, 2024 | 01:07 AM
cetialpha5's Avatar
He did tell you, just in his normal style. You need the vin number to punch into EPC and then you'll have the correct sway bar part number. You can get a knock off copy of Mercedes's EPC on eBay for around $7 but if you post the vin, maybe some kind soul who has a copy of EPC or ISPPI will look it up for you and tell you. I wouldn't bother getting one from a junkyard. The problem with the MB sway bars is that the bushings are glued onto the bar and they make a noise once they're loose so why would you want a used sway bar where the bushings are either loose or will be soon? They don't make aftermarket bushings for the sway bars. The price of the sway bar has also come down over the years, maybe around $70-$100 depending on the model.
If you get the EPC, it also comes with WIS which is what you really want, it's the full dealer repair manual that the dealers used. Discontinued in 2018/2019 but still good for the older cars.
Old May 24, 2024 | 02:15 AM
MikeDanger's Avatar
bmw E39 540i
I did look up parts through some online source, they all appear to have the same PN#, which is slightly disappointing. My previous bmw 540iT , had the sport package and I put in a rear M5 sway bar. Really was hoping I could get similar handling out of this one
Old May 24, 2024 | 03:06 AM
cetialpha5's Avatar
Basically you can't trust those online sources. EPC will get you the right part number. There's not that much aftermarket support for Mercedes in terms of optional performance items, pretty much it's all stock. You're going to get whatever handling it had when stock. I suppose if you had EPC, you could check out an AMG version and see what the sway bar part numbers were and check the diagrams and see if they might fit or not. But I never looked into that. While people like to talk about performance and all that, it rarely comes into play in every day driving.
