Jerky acceleration E320 om642
i am having this annoying problem with my E320 om642 and can’t seem to figure out the problem. It’s got a jerky acceleration when flooring it, it starts around 2500rpm. Had a scanner on it and the only code is P1103 maf sensor. A month ago I replaced the turbo actuator because it was bad. After I replaced it the car was running fantastic. But now the actuator isn’t moving, I am confused if the actuator already is bad again or, I need to replace maf sensor. I figured maybe the reason actuator wasn’t moving anymore was because of the maf sensor but I have no idea. I also tried the swirl flap delete with no luck. Because someone described almost exact my problems and it worked for him.
I have replaced air filters and fuel filter.
hope someone can guide me towards a solution
You can also test the actuator somewhere in those menus and I do not recommend the swirl flap bypass just let the engine be. I’m at 285k miles and no issues
