E-Class (W211) 2003-2009
Help! Need the differential ratio W211 E200
Old May 30, 2024 | 06:30 AM
rkoforever90's Avatar
W211
So my w211 differential was faulty and I gave it to my friend's garage.
He replaced it with the wrong one and the gears are not shifting past 3rd.
Now I came to know from a Mercedes Benz expert that each model has a unique differential ratio,
and knowing the ratio of my model is needed to find the differential with exact fit for my car. I was wondering it anyone know (or know from where i can get) the differential ratio of W211 E200 2008 face-lift model.
Old May 30, 2024 | 01:49 PM
Heguli's Avatar
2006 E280
Are the old gears still available, or did your friend threw them away? Ratio is either stamped to the gears, or just count the teeth and divide ring with pinion.
Old Aug 28, 2024 | 07:52 AM
W211
Originally Posted by Plutoe
you can go to any dealer with your VIN and they will tell you the ratio and the appropriate part number(s) for differentials for your VIN----its simple and not rocket science
i did manage to get the differential ratio and changed the differential but still the tranny is going into limp mode like refusing to shift beyond 3rd after a few minutes of drive
