E-Class (W211) 2003-2009
W211 healight led module part number A2119060036/A211906003664
Old Jun 12, 2024 | 12:00 PM
buhejji's Avatar
E280 2007 w211
Hi everyone could someone be life saver by letting me know where can i get this i kept surfing the internet but its out of stock unfortunately.So if someone knows from where can i get this part i can use your help Thanks!!
And also if there any other option just incase i couldn’t find one.
Is it to possible to cancel it and just connect a T10 connector by connecting the wires?
please help meeee i could use any info and help
Thanks!!
Old Jun 12, 2024 | 04:26 PM
buhejji's Avatar
E280 2007 w211
Originally Posted by Plutoe
try auto haus----google the part number
Unfortunately not available
Old Jan 12, 2025 | 12:20 AM
Calebhill31's Avatar
2007 E63 AMG
Any luck finding a module? I’m on the same goose chase
Old Jan 13, 2025 | 12:16 PM
timmy0tool's Avatar
2008 S211 4MATIC
same boat here as well. i'm tempted to remove it from the headlight and see if the PCB or other board components are repairable...but can i even remove it from the high beam lens while installed in the car?
i see only 1 torx screw but it's at an odd angle (since it's likely meant to be screwed in w/o the headlight housing in place). i'll give it a shot when i have the time.
Old Jan 13, 2025 | 12:28 PM
timmy0tool's Avatar
2008 S211 4MATIC
thanks, never knew about MBPG! remove the leading "A" from the part number and boom, it's there!
