722.9 slipping after rebuild
So I have a 2006 e350 with the 7g Transmission. Had to have the conductor plate repaired so while it was out, I put all new clutches in. I air check all of the drums and found zero leaks anywhere and there was zero signs of heat stress on any of the steels. The clutches all still had writing on them as well so I assume they had not worn much. Well I reused the old converter, put the conductor plate back on and reassembled the transmission. NOw I have a 0741 code after driving it for two days and it slips a light throttle 1,2,3, and 4. Heavier acceleration and it shifts fine but slower acceleration gives slip in standard mode. Comfort mode seems to shift just fine but I still have the code issue. Is there anyone on this forum that can help me diagnose what the issue is. I think that the converter is going to need replacing but I just want to be sure. This is the only code and it drives down the highway at 96*c. Thank you
