E-Class (W211) 2003-2009
E320 Wagon, 2009
Old Sep 24, 2024 | 10:57 PM
Malcolm Scott's Avatar
E350 Wagon, 2009
Thumbs up E320 Wagon, 2009
My car has codes P0016 and !7. My Indy says it will cost 5-6000 to repair. Car not worth that much so am going to sell the complete car for parts. Just about everything on the car works good.
Anyone interested ?
Old Sep 25, 2024 | 10:48 AM
jimyj's Avatar
E320
The P0016 code indicates a mismatch between the crankshaft and camshaft position sensors, which can be caused by a variety of issues. This could stem from a faulty camshaft or crankshaft position sensor, which disrupts the engine's timing and synchronization. Additionally, problems with the timing chain or belt, such as slipping or stretching, can lead to this code by altering the relationship between the crankshaft and camshaft. Another potential cause is a malfunction in the variable valve timing (VVT) system, which relies on precise timing to optimize engine performance. If the VVT solenoids are failing or there's oil contamination affecting the system, it can also trigger the P0016 code. The !7 code might be related to these timing or sensor issues, further indicating a broader problem within the engine management system. I recommend running a full system scan to identify any related fault codes across the vehicle's control modules. There should be codes stored that can help pinpoint the exact cause of these issues. You might need to take the car to a mechanic for a comprehensive diagnosis, but if you're comfortable troubleshooting further, the youcanic full system scanner is excellent for diagnosing all systems. Just ensure you use a full system scanner, as some tools might not read all vehicle systems and could miss important codes. I hope this helps and you're able to resolve the issues with your E320!
Old Sep 25, 2024 | 06:37 PM
E350 Wagon, 2009
2009 E350 Wagon
Thanks. Done all the checks and need new Inlet manifold also as flapper valves not operating correctly. Don't understand why, all of this happened all of a sudden. Shame but that's life
Because of cost of repairs exceeds value of the car, have decided not to repair even though everything else works perfectly. Shame but I predict there will eventually be other problems. Will either sell to a junk dealer or swell for parts.Thinking of buying a 1984 300 SD. Diesel and without all these electronic parts and systems.
Old Sep 28, 2024 | 05:37 PM
Pig's Avatar
Pig
E500
How many miles on that vehicle?
Old Sep 29, 2024 | 12:48 PM
E350 Wagon, 2009
Mileage
Mileage 183 thousand + a few
Old Sep 29, 2024 | 02:05 PM
trigital's Avatar
W213 All-terrain
More likely your engine is infamous M272 (E350) so your Indy is right.
