W211 AC System in a W201
maybe a bit strange, but i am building a W201 where i will install the M113 5.0 engine with a 8HP45 gearbox, which will be controlled by the standalone MaxxECU.
I will most likely build my own dashboard after i have scanned the the inside of the car, but besides the wiring and the ventilation ducts dont want to have anything else there, because i want the engine as close as possible to the firewall and i believe that the original vent that sits in the middle of the wirefall will not fit anymore, or even if it would fit, i still dont want it there to have more space around the engine and my plan is to install it in the trunk where also the battery will be mounted.
Now to my question:
Is it possible to use the W211 or e.g. W220 (or from any other model, it doesnt really matter) Air conditioning system with the ventilation box, blower, control module and control panel? Is it a "standalone system" or somehow connected with other modules from the W211?
I hope you understand what i want to achieve. The M113 5.0 Engine comes from the W220 S500 and has the original AC pump.
My first plan was to use a chinese 12V AC System and install it in the trunk, but thats not the best solution, because i would then need to build a ventilation box with flaps and control it somehow, which i would manage to get done, but lots of work. Its a lot more complicated then buying a original ventilation box, modules, etc..
If thats possible, then it would be the perfect solution and i could slowly order the necessary parts.
Hope you can help me out with that.
Thanks in advance,
Br Denis
The standalone ecu has to do with the AC system. (Even if it is capable of turning the the pump on and off at specific situations)
just read my post again. If you still don't get it then it seems you have no knowedge, so please just don't reply to my post.
I expected an answer like e.g. "yes you can do it, ..." or "no, its not possible, because the modules are connected to the w211 ECU or other modules" or something like that.
So, just one more time.in short: i asked if i can put the whole Air conditioning system (all parts/modules, panel) of e.g. a w211 to the w201 project car, so that I can turn on and off the AC pump, set up temps, control the flaps (window blow, legs, etc,.) via the w211 control panel..
