E-Class (W211) 2003-2009
Have you changed your inner tie rod?
Old Nov 17, 2024 | 01:20 PM
KCe550's Avatar
2008 e550 base WDBUF72X98B228774
My '08 E550's are limp so I'm replacing both sides. Mine are on too tight to remove with pliers (I've tried), so I picked up a universal inner tie rod tool kit. It seems the better kits include 40mm and 42mm crowfeet wrenches but not the 41mm required. More critically, the tools all measure between 16 and 20 inches long, whereas I have about ten inches of clearance to work without removing the entire hub assembly to accomodate that length. I'm considering fabricating my own tool from steel pipe, but that will take awhile. I wonder what others have done? I suppose my other option is remove the entire hub assembly to fit the 20" tool, but I've done backflips to avoid having to do this up to this point, and tbh am not sure how to do it. I could also cut the tool down but need to figure out how to properly weld the joint to withstand 110Nm of torque when reinstalling.
