E-Class (W211) 2003-2009
Key wont turn in ignition switch
Old Nov 24, 2024 | 12:03 PM
Nippels's Avatar
Hello i just bought mercedes w211 and it has problem that key dont always turn in ignition switch. Sometimes i have to insert it multiple times until it works. If i turn key in meantime when inserting, it usually helps. But it is annoying and im afraid that it will go worse.
can it be repaired or cleaned or do i need to change ignition switch? If i change it, does it need coding?
also instrument cluster has a brake pad wear error. Can it be deleted. I have new pads and rotors, but sensor is broken and i really think that it is useless
