E-Class (W211) 2003-2009
2007 Bluetec DPF and Limp Mode
Old Dec 19, 2024 | 12:02 PM
ballyroebuck's Avatar
1992 300TE
In spite of the badge, my 2007 OM642 Bluetec is actually a CDI. No DEF fluid needed. After a oil cooler seal change, I found my DPF filter was throwing the P242F code. Driving at 2000-3000 rpm didn't clear the DPF and its code, but put the car into limp mode.
On YouTube I saw a mechanic put foaming cleaner into the DPF via the sensor hose and would like to give that a try.
I see where the sensor is located on later OM642 W211's, but it's somewhere else on my 2007.
Anyone know where it's located?
Old Dec 20, 2024 | 08:36 AM
Heguli's Avatar
2006 E280
Are you talking about the DPF pressure sensor? On my '06 it's mounted to the chassis, left from the transmission.
Old Dec 20, 2024 | 09:10 AM
1992 300TE
Yes. I was hoping it would be more accessible. Saw a YouTube video where a mechanic used one of the sensor lines to introduce cleaner into the DPF.
Old Dec 20, 2024 | 04:11 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
I can't imagine any chemical harsh enough to clean out a coked up DPF that wouldn't also eat through the metal housing, gloves and your skin.. If you've ever opened one of these things up after they're clogged, it's like a kiln with years of multi-layered baked on carbon. There are industrial dpf cleaning machines that are usually intended for commercial vehicles, like busses. If you do find a magic solution to restore your DPF to working function by simply using a foam injected into a port while the DPF is still mounted, it would be a game changer.
I say this as someone who's OM642 clogged up at 140K and I ended up just deleting it. I have a new diesel pickup, and if there's no delete by the time the emissions/drivetrain is no longer under warranty, I'll be selling that one.
Old Dec 22, 2024 | 09:28 AM
1992 300TE
WDBUF22XX7B089742
