Orienting after first DIY suspension change
I pulled the car out of the driveway and drove around the block to test it out before planning to do the passenger's side. A few things catch my attention.
First, I get a warning that ESP is not functioning, check my owner's manual. The warning was not there when I parked in the driveway momentarily and started up again, but was on while driving.
Second, I see my camber is so negative as to be cartoonish. I have to wonder if it's ok driving this thing 25 minutes to the dealership for an alignment as planned.
Third, the control arm bushing that I just installed--the rubber is coated with a fuzzy whitish powder. Strange, I don't remember this when I installed just moments ago.
Does it sound like I messed up? I did try to torque everything in approximately "drive load" although that was hard to guess accurately.
Odd question...do new Lemforder control arm bushings turn white for any reason? Mine were installed today and noticed the black rubber is covered with a course fuzzy white powder. Curious if this signals anything. No worries If you have no idea, I've just never seen it before.
Thanks for contacting FCP Euro!
I am happy to confirm that it is normal and you should be all set!
I believe that it is due to a substance they use on the bushings to make sure they do not deteriorate while in the warehouses.
I'm here to help with any further questions or concerns!
Best regards,
Sean C
The ESP error is common after replacing control arms. It can occur if the alignment gets too far out of spec. The dealership automatically fixed this when I took it to them for an alignment. I'm not sure how. I read during my research that it can also be set off by the steering wheel sensor being too far out of spec of center, and that can be reset by turning the steering wheel back and forth several times between extreme left and right. Whatever the ordeal, the dealership took care of it.
Second, camber out of alignment is expected after a control arm change. Next time I think I'll make sure my steering wheel is straight ahead but yes I drove to the dealership fine. Also it wasn't as bad upon second glance.
Still unsure as to the white powder. I did the second side and showed pictures above of the control arm bushing completely black, but towards the end of the installation I noticed some white powder there too.
Doing the second side was much faster than doing the first side, as there was a learning curve and tools I needed to buy (Mercedes-specific ball joint C clamp, tight ninety degree pneumatic impact wrench, E-sockets, probably other things). Doing all the arms, ball joints, sway bar links & new hardware at once made the most sense. Car runs like a creamy dream with new suspension!
as for the white powder, it's perfectly normal since the rubber was at "rest" for so long in storage that a very thin film has formed. now that it's in use it's being exercised. the white powder is just that surface film stretching and getting exposed to the elements/oxygen/etc.
