What should I pay attention to when buying a w211 e500?
Subscribe
Jan 24, 2025 | 08:09 AM
Hello, I want to buy a w211 e500 to travel to my hometown in the summer and I will travel a total of 10-15 thousand kilometers in a year. What should I pay attention to? How many kilometers should it be? I would be happy if you help
Reply 0
Jan 24, 2025 | 10:22 AM
The W211 E500 is an excellent car, but there are several important things to consider before buying one, especially if you plan to travel 10,000–15,000 kilometers a year. One of the key areas to check is the AIRMATIC air suspension, which provides a smooth ride but can be costly to repair if it fails. Make sure the car sits level when parked, and look out for any suspension warnings on the dashboard. Another area to pay attention to is the engine’s timing chain and balance shaft, as these can be a concern for certain model years if not properly maintained. Always ask for maintenance records and prioritize cars that have a solid service history. Additionally, check for smooth shifting in the 7G-Tronic transmission, as rough or delayed shifts can indicate wear or a lack of regular transmission servicing.
Before finalizing your purchase, I highly recommend performing a full system scan to uncover any hidden issues in the car’s electronics and mechanical systems. Many problems won’t be immediately visible during a test drive, but a full diagnostic scan can reveal faults in the engine, transmission, suspension, and more. If you don’t already have a scanner, the YOUCANIC full system scanner is an excellent choice. It’s a tool I use personally, and it’s incredibly thorough for diagnosing potential problems in cars like the W211. With a proper inspection and diagnostic scan, you can ensure that your E500 is ready for the road and capable of handling the mileage you have planned.
Reply 0
Jan 24, 2025 | 10:52 AM
[QUOTE=jimyj;9102050]W211 E500 mükemmel bir arabadır, ancak özellikle yılda 10.000-15.000 kilometre seyahat etmeyi planlıyorsanız, satın almadan önce dikkate alınması gereken birkaç önemli şey vardır. Kontrol edilmesi gereken temel alanlardan biri, yumuşak bir sürüş sağlayan ancak arızalanırsa onarımı maliyetli olabilen AIRMATIC hava süspansiyonudur. Araba park edildiğinde düz durduğundan emin olun ve gösterge panelinde süspansiyon uyarıları olup olmadığına bakın. Dikkat edilmesi gereken bir diğer alan da motorun zamanlama zinciri ve denge milidir, çünkü bunlar düzgün bir şekilde bakımı yapılmadığında belirli model yılları için bir sorun olabilir. Her zaman bakım kayıtlarını isteyin ve sağlam bir servis geçmişi olan arabalara öncelik verin. Ayrıca, sert veya gecikmeli vites geçişleri aşınma veya düzenli şanzıman servisi eksikliğinin göstergesi olabileceğinden, 7G-Tronic şanzımanında yumuşak vites geçişleri olup olmadığını kontrol edin.
Satın alma işleminizi tamamlamadan önce, aracın elektronik ve mekanik sistemlerindeki gizli sorunları ortaya çıkarmak için tam bir sistem taraması yapmanızı şiddetle tavsiye ederim. Birçok sorun test sürüşü sırasında hemen fark edilmeyebilir, ancak tam bir teşhis taraması motor, şanzıman, süspansiyon ve daha fazlasındaki arızaları ortaya çıkarabilir. Zaten bir tarayıcınız yoksa, YOUCANIC tam sistem tarayıcısı mükemmel bir seçimdir. Kişisel olarak kullandığım bir araçtır ve W211 gibi araçlardaki olası sorunları teşhis etmek için inanılmaz derecede kapsamlıdır. Uygun bir inceleme ve teşhis taramasıyla, E500'ünüzün yola hazır olduğundan ve planladığınız kilometreyi kaldırabileceğinden emin olabilirsiniz.[/QUOTE
] Thank you for providing comprehensive information As far as I understand, as long as it is well-maintained like a normal Mercedes, it will not cause any problems and the mileage does not matter much. Will it work if I buy an affordable product from Aliexpress other than Youcanic?
Reply 0
Subscribe
Currently Active Users (1)
