E-Class (W211) 2003-2009
vibration problem with w212
Old Feb 7, 2025 | 12:49 PM
hendriw212's Avatar
Can someone understand what could be wrong or does somebody have any ideas why this is happening?
I have a vibration problem with my MB W212. Vibration occurs when the car is on a slope in the 'P' position. And while driving, when torque is applied. In the 'Park' position on a flat surface, there is no vibration. (The engine mounts have just been replaced.)
Any ideas?
Old Feb 7, 2025 | 12:59 PM
W205C43PFL's Avatar
Any ideas?
What about transmission mounts?
Old Feb 7, 2025 | 01:39 PM
hendriw212's Avatar
changed aswell
Old Feb 7, 2025 | 01:41 PM
hendriw212's Avatar
Originally Posted by Plutoe
are there any types of sounds associated with this vibration
no sounds
Old Feb 7, 2025 | 03:34 PM
W205C43PFL's Avatar
Is the vehicle equipped with airmatic?
Old Feb 7, 2025 | 04:44 PM
hendriw212's Avatar
yes it is
Old Feb 7, 2025 | 05:01 PM
W205C43PFL's Avatar
yes it is
I wonder if that has to with it, if it is worn, as in the pressure, inflation etc. Kind of a stretch I guess.
Old Feb 9, 2025 | 05:06 AM
hendriw212's Avatar
We installed new front airmatics couple of days ago, rear airmatics are OK I think|
Old Feb 9, 2025 | 10:44 AM
W205C43PFL's Avatar
I see, in that case, I wonder if the different levels of wear is causing this? new vs old components on two axles.
Old Feb 11, 2025 | 12:18 PM
vagt6's Avatar
2004 W211 E320 Sport
Check engine and transmission mounts. Not hard to do if you can get the car safely elevated.
Old Feb 11, 2025 | 12:30 PM
W205C43PFL's Avatar
If I understood it correctly, OP changed all 3 already.
