E-Class (W211) 2003-2009
High fuel consumption on E280
Old Feb 9, 2025 | 03:50 AM
jave808's Avatar
2007 W211 E280
Question High fuel consumption on E280
Hi
I've noticed that the fuel consumption of my W211 E280 is high around town. Like up to 15L/100km fuel consumption. I'm thinking that it could be the E10 fuel that I use. A mechanic friend suggested I try running it on 95 octane fuel and see if things improve.
Has anyone had this problem before? Car has done nearly 120000km and is serviced regularly. I had the inlet manifold replaced back in November 2023 and all camshaft sensors replaced.
Old Feb 11, 2025 | 07:11 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Your mechanic's suggestion is the right one. Higher octane fuel provides better economy. Do you have a scan tool? You should check the Fuel Trim measurements with E10 and then again with 95. I bet they'll show a difference if it's just the fuel quality that's your problem
Old Feb 11, 2025 | 07:52 PM
jave808's Avatar
2007 W211 E280
Thanks guys for the confirmation of fuel quality. I have a scan tool and will do some checking of the live fuel trim data.
