E-Class (W211) 2003-2009
trunk closing linkages
Old Apr 3, 2025 | 10:32 PM
Jack Bat's Avatar
hi, i own 04 e55 amg and im trying to restore it.The rear trunk lid used to have electronic open/ close feature but the arm is disconnected from the trunk henge. i could not figure out how to reconnect it and see if it gonna work. also the panoramic roof is not working and i have to take it a part to see if the cables are broken.No noise at all as far i remember. the remote lock/ unlock does not work most of the time. it is new keyfob from the dealer. message cornering lights is on the display. Any info will be much appreciated.
Old Apr 4, 2025 | 09:25 AM
streborx's Avatar
Top Answer: 1
G550
A picture would help, but if you're referring to the air piston component that keeps the lid open and a connecting point that is a ball topped stud, the piston rod's end snaps over the ball, and is retained by a spring clip on the rod end. Removal requires a small screwdriver blade inserted under the spring to pry it up just far enough to clear the ball.
