E-Class (W211) 2003-2009
Dry and Brittle, what???
Old May 28, 2025 | 03:44 PM
Bounder's Avatar
2003 E500, 52k miles
Today while cleaning all the leaves, acorns and twigs out of my engine bay, I noticed a large hole in one of the large diameter plastic vents tubes (?) that run on both sides of the Mercedes dust cover. Given the age of the car, not surprised how brittle the flexible plastic "accordian" section of the tube is. The opposite side is very brittle too but less advanced.
Am I correct in thinking these large diameter vents provide fresh air into the cabin? I say this because each seems to be attached to the backside of the front grill. Thanks.
2003 Mercedes E500, 81k original miles.
Right side, driver pov.
Left side, driver pov
Old May 28, 2025 | 03:46 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Normal, you can get replacements all over the place. Amazon, where ever. And no, they do not at all provide interior air. That is engine air, and it is before the filters.
Old May 28, 2025 | 03:55 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
@Bounder
the interior air intake filter and inlet is located in the back left of the engine compartment as you are standing in front of the car. 10mm plastic nut, lift cover, pull and replace activated charcoal filter. Check your auxiliary battery while you are in there; if the main battery fails, that auxiliary battery is the only source of power for your brake-by-wire SBC system.
Old May 29, 2025 | 08:11 AM
Bounder's Avatar
Ah, engine air, thanks.
Old May 29, 2025 | 08:23 AM
On my E350 they have been missing (I took them out to replace them)....well, about two or more years ago :-)
