E-Class (W211) 2003-2009
Front axle problem
Old Jun 15, 2025 | 06:09 PM
shnazzdad's Avatar
W211 E500
Front axle problem
I discovered why the splines on the passenger side front axle (2004 E500 4matic) won't go all the way into the transfer case. There is a smooth round 1/2" pin (?) at the far end of the splines that's blocking the axle spline from going all the way in. What happened? Did something break internally? Is there a way to recess the pin to allow full entrance into the transfer case? Thank you.
