E-Class (W211) 2003-2009
W211 Level Sensor installation
Old Jul 8, 2025 | 01:33 PM
vagt6's Avatar
2004 W211 E320 Sport
My '04 E320 Sport W211 has a failed Level Sensor in the rear.
How difficult/how long to install a rear Level Sensor?
Thanks, all.
Old Jul 9, 2025 | 09:05 AM
vagt6's Avatar
Regardless, my Benz mobile mechanic(s) is coming today to install a new Level Sensor.
I did a Google search for prices on Level Sensors, seems they're cheap at $35-$50. No info on installation time.
In the meantime, if anyone has such experience, please let us know.
Here's what Google AI says
The installation time for a Mercedes-Benz W211 level sensor can vary, but generally takes between 1 to 2 hours, according to a car parts website. The exact time depends on the specific location of the sensor (front or rear) and whether any other components need to be removed or adjusted for access.
Here's a more detailed breakdown:
  • Front Level Sensor:
    Replacing the front level sensor usually involves removing the wheel and potentially some suspension components to access the sensor. This can add to the overall installation time.
  • Rear Level Sensor:
    The rear level sensor may be easier to access, but the process can still take some time depending on the specific setup of the W211 model.
  • Overall Time:
    The process may take longer if you are unfamiliar with the components or if you encounter any unforeseen issues during the replacement.
  • Recalibration:
    After replacing the sensor, you may need to recalibrate the system using a diagnostic tool, which can also add to the time required.
Old Jul 9, 2025 | 02:00 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Easy to replace. Maybe 2 screws and 2 small bolts or nuts and one connector.
You will need to recalibrate ride height after replacement. I have posts on how to do so. STAR/Xentry will guide you through the process and you will need an inclinometer app on your cell phone to verify inclination angles.
Old Jul 10, 2025 | 07:59 AM
vagt6's Avatar
Some have Level Sensors at each corner, some have only two, one at rear. Depends on the W211 model. Mine is an E320 Sport with 3 position suspension settings and four Level Sensors one at each corner.
Took (highly experienced) Mercedes mechanic about 2 hours to install.
I'll be back soon, I'm going to rob a bank to pay for this.
Actually I have a great connection to a mobile Mercedes guy who comes to my home and at $120/hr repairs my Benz(es). The local Mercedes dealer charges $200 plus per hour and is so busy it's hard to get in the place.
I'll report again when I get the bill.
Old Jul 11, 2025 | 11:08 AM
vagt6's Avatar
Thanks, much appreciated.
