Brake Wear Help
Thanks to everyone.
Thanks to everyone.
If I remember correctly, not too many pads come with a thickness over 14mm (I could be wrong). So it sounds like you are going to get well over 30k out of the fronts, but the rear are not going to last as long.
Also, you seem to be in the minority since your brakes are not that worn out by 10k. However, your rear pads do seem to be wearing faster than the front which seems to be a pattern in the W211. My car has 4000 miles and the pads are still very thick (this is what I would expect).
Hope this helps,
Steve
